Motorhome batteries went dead.
Old 03-20-05, 05:02 AM
Bkorne
I have a 2004 Dolphin class A MH on a workhorse chassis. The last time it was in storage for about 6 weeks the 2 6-volt house batteries and the 12-volt engine battery went dead. I recharged all 3 at home, but now worry about a repeat. At this time I am disconnecting one of the cables for each system when I store the MH. When I touch the cable to the battery post there is a spark. This indicates to me a draw on the batteries. How do I measure that current to determine if it is excessive and will run the battery dead again? Should I simply add a battery isolator switch and turn it off when stored? The MH has a house battery connect switch which I turned off, but there is still a spark when I touch the cable to a post.
Bob
Old 03-20-05, 03:24 PM
if you get a spark than somthing is on to isolate the problem and find what it is you should start pulling fuses on at a time to find the sorce once you find the fuse see what is in that system to find the problem device which is on
putting in a shut off only hides a potential problem for later
