Thermostat question, 1988, 460 cid
Old 03-22-05, 09:59 PM
SMOEKO
I have recently bought a 1988 Class C RV with a 460 ford engine. The neele on the Temp gauges is running on the upper end of the normal side. I am thinking the Thermostat needs to be replaced. If so what Temp. on the thermostat would you recomend. Thanks.
Old 03-22-05, 11:20 PM
This woud have come with about a 192 or 195F thermostat. If it still runs hot after the new stat, I would recommend checking the flow through the radiator.
