92 dodge ram
Old 03-30-05, 07:21 AM
vram52
92 dodge ram
Windows , heater motor , ac , back up lights do not work. All fuses and relays are good . Cannot get any to work. Any got any ideas.
Old 03-31-05, 03:37 AM
did you check all fuses or fusible links under the hood? you can pull on fusible link wire if it stretches and pulls apart easily then the link is blown.
Old 03-31-05, 04:47 AM
vram52
92 dodge ram
tryed that could not find any bad ones
Old 03-31-05, 05:01 AM
if you have a test light use it to check for power through the fusible links and through the fuses if no power at fuses with key in the on position check the ignition switch as it may be bad and not providing power to some fuses in the fuse block.
Old 03-31-05, 05:56 AM
what motor and size truck is this ??
4x4 or not ?
Old 03-31-05, 06:40 AM
vram52
This is a B250 van with a 318 FI
Old 03-31-05, 08:05 AM
vram52
92 dodge ram
I forgot to mention that when I try the windows , heater ,or back up lights the parking brake warning light comes on. Weird !!!
