HELP !!! Oil pump on 91 F150 W/5.0
I am trying to change the oil pump on a 91 F150 with a 5.0 I have removed all of the bolts to the oil pan and the exhaust pipe is in the way as well as the cross member and the I-beams. What do I have to remove or take off to get the oil pan off to get to the oil pump, or do I have to jack the motor up or what? Please HELP!!!
Jimbo21
Jimbo21
Received 0 Votes
well here goes you picked a good one to try first you remove the pan bolts as you did
than you must remove the motor mount through bolts so you can lift the engine after you lift the engine (watch out in the back of the engine that nothing gets broke on the fire wall some model years you had to remove the upper intake plenium)
than you have to get your hands inside the pan toremove the pickup screan which is bolted after yo remove the pick up just let it lay in the pan and try and wiggel the pan out some have to remove exhaust some dont
well good luck and have fun with it
i beleve it calls for aprox 6 hours labour in a shop with proper equipment
Oil pumps are usually changed because of low oil pressure problems. Be sure to verify the gauge is accurate first. The sending unit can be bad giving a false reading.
