88 Ford F150 Manual Trans.
Cant find any owners manuals , so I came here desperatly seeking help.
5 Spd. Manual Trans.
Wanna drain the oil out.
Does it take the ATF fluid or does it take Gear Oil (90 weight i presume)
you need to know what trans you have the 4 spd uses 80wthe 5spd mitsubishi uses 80w all other trans use Mercon your best bet uould be to let a littelout and see te colour if its red its Mercon
