94 blazer
94 blazer
the problem is it wont start it trys but wont keep running it seams like it is starving for gas but it is getting gas what could it be
check fuel pressure if its a port fuel injected engine it will require 55 psi minimum to start the fact that fuel is coming out of the filter doesnt really tell you anything, a weak pump may be capable of producing 50 psi and cause a no start condition.
yes check pressure these 4.3's need exact pressure i have seen then a couple lbs out and cause a no startonce thay get running not as critical try priming the system a few times before starting this may help determin if its a pump or not
