RV Turn and Brake light not working
Old 06-05-05, 08:54 PM
mwl
I have an RV built on a 1992 Ford E350, 460Cu. In. Motor. The turn signal and brake light on the left rear of the vehicle aren't working. I've tried tracing the wiring and there is no signal all the way back to the drivers compartment. I can't find the correct wire once it goes up into the cab. Does anyone know of a good reference for the wiring on this truck. I bought a Chiltons manual that said it included wiring diagrams, but the diagrams are so generic they are all but useless.
Old 06-05-05, 10:33 PM
you might check autozones website they have some diagrams for a e350 the wire colors may not match exactly here is a link not sure if it will work.
http://www.autozone.com/images/cds/g...3d801775b4.gif
suggest starting at the turnsignal wiring at the base of the steering column and test to see if power is getting through the turnsignal switch.
