2000 ranger xlt belt
Old 06-14-05, 06:10 AM
jp13's Avatar
I own a 00 ranger xlt, 6 cyl automatic. My problem is when I start the truck up in the morning my serp. belt squeals terribly then goes away. Could it be a bearing also. The truck has 37000 miles on it. Is it easy to change these belts?
Old 06-14-05, 07:46 AM
yes belt is fairly easy to change it has an automatic tensioner just releave the pressure and remove the belt make sure you have a belt diagram if not draw one before takeing it off some can be frustrating also check all puleys and bearings
Old 06-14-05, 11:31 AM
new belt never hurts. If it still sq. after that/how old is the battery. If the battery is loosing its charge after sitting the alternator has to work extra hard to boost it back after you crank it.
