Ford 350
Old 06-21-05, 04:30 AM
bicounty
96 F350 Limited slip rear end
When I back up I hear a clicking sound coming from the rear axle area. Worse when I turn the wheels. I thought it might be the brake adjusters stuck. I pulled the drums and cleaned the adjusters and manualy adjusted but still have the noise. I think it must be in the limited slip rear end. Does this mean the rear end will have to be replaced? Can I fix this short of replacing the rear end? Will I damage other coponents driving it,such as transmission and transfer case?
Old 06-21-05, 05:54 AM
if the problem is in the differential it can be rebuilt if you let it go to long excessive damage in the rear end can occure but i would start with checking the "U" Joints to start with
Trackbacks are On
Pingbacks are On
Refbacks are On
