Engine will start but won't idle
Old 08-08-05, 08:54 AM
ronniehale
Originally Posted by jeffstevens
Anyone troubled over a problem? (automotive) Ask a question I'm here to help.
I have a 1999 F-350 6.8L V10. 135,000 miles. Engine will start but won't idle. Pressure on accelarator will keep engine running even at low RPM. Once you take foot off, engine dies. Tried Fuel injector cleaner, and fuel treatment.
Just won't idle, even when warmed up. Any suggestions? Thanks.
Old 08-08-05, 09:12 AM
mancoowner's Avatar
we all are
Old 08-08-05, 08:45 PM
jeffstevens
How does it run under load? Any check engine light?
Have you done a tune up? You may have to replace the TP sensor, or maybe a PCM reflash. I need more info.
Old 08-09-05, 06:01 AM
try cleaning the throtal body and idle air motorwith air intake cleaner this is a commen problem
Old 09-03-05, 02:45 PM
lucky131352
lucky131352
how to replace clutch starter switch in 1994 geo tracker 2wd.....won't start....isn't battery and just replaced a 60A fuse on engine frame in front of battery........
