96 k1500 stuck in 4L
Old 08-08-05, 02:08 PM
mikeb
1996 k1500 is stuck in 4Low. Electronic transfer case. Checked for broken retaining ring. Are there any other common things to check for b4 taking it to shop? (actuators?)When you press the 4H or 2H buttons, the relay under the dash clicks several times and the corresponding light flashes, but it stays in 4L.
Thanks
Old 08-09-05, 06:04 AM
the only thing to check wouild be that there are no broken wires going to the transfer case if not than if you do not have lots of experance to the shop it should go
