truck intermittent stalling
Old 08-23-05, 09:31 AM
daswede's Avatar
1995 chev ,k2500 stalls sometimes when directional signals are activated.
Suspect a short some where ,but need some help on where,or,how to trouble shoot the problem.
Thanks
Old 08-24-05, 05:56 AM
start with the signal switch and start tracing but first if any bulbs have been changed before this has started check them first make sure thay are in correctly and the correct bulbyou can pull bulbs one at a time and see if it stalls if not put it back ane try again if it dose than check socket and circuit also check ignition switch for bad wire while in the column
good luck it sounds like a fun one just remember Use the KISS Theory
KEEP
IT
SIMPLE
STUPID
Works every time
Old 08-24-05, 06:02 AM
daswede's Avatar
Thanks,
I keep your suggestions in mind. I think this one is going to be a 'bear'.
