1999 Dodge 1500 brake/speedometer problem
Old 08-24-05, 05:31 AM
Ratheon
Having a problem with a 1999 Dodge 1500 5.9 4WD VIN Z. Error code reads speed sensor. Check engine,ABS, brake warning lights are on. Speedo stays at 0 and transmission in 1st until you hit 35mph. At that point it will shift and indicate correct speed. I'm going to replace the speed sensor....but which one? There is one on each differential and they are of different design.
Old 08-24-05, 05:44 AM
i would guess the one on the trany if there is not one on the trany than the speed is taken from the rear
Old 10-07-05, 11:51 PM
You need to replace the sensor in the rear diff.
About $40.00 for the part at your local dealership (yes, it's a Dealer Item Only). DYI install about 5 min.
