1996 Chevy PU Electrical Problem
Old 09-18-05, 08:59 PM
jmwsooners1
I have a 1996 Chey P/U 3/4 ton I bought new. Over the years I have had a continuous problem of it burning out the the the turn signal/break light curcit board on the driver side of the truck. I have replaced this board six or seven times. Does anyone have an idea of what the cause for this might be? Also, this truck came equipted with a safety feature of having the headlights burn at a low level anytime the truck was running. These lights do not burn anymore when the truck is running. Could this have any connections to the turnsignal/break light circut board problem?
Old 09-22-05, 12:59 PM
i havent run accross any problems with the bord make sure no moisture is getting at it and it is properly grounded
as for head lamps sounds like the day time running lamp module is bad located under hood by relay box
