flywheel bolts cross threaded
Old 11-10-05, 03:16 AM
i have a 1993 ford ranger p/u reg. cab 2.3l, fi, 4 cyl.,2wheel drive. i am changing out the clutch, flywheel, pilot bearing and various other things while i am there. when i installed the new flywheel i cross threaded 2 bolts that went into the crank. can i tap these out. any suggestions? the bolts are a 9mm or a 10mm.
thanks, gary
Old 11-10-05, 09:11 AM
Heli coil is your only solution you can get a kit at a aftermarket parts store or if you have a local machine shop thay may be able to sell the kit and also may be able to send one of there machinest to install for you
Good luck
