plow light ?
plow light ?
I am getting ready for my first year of snow plowing. I'm interested in opinions on the top of cab strobe/rotating lights that can be removed when not in use, maybe the kind that plugs into the cigarette lighter. I want be visible as much as possible with a limited budget.
Thanks
Thanks
i found that the cig plug lamps are not good enough and do not last as long as a permanent mount ones your best to go direct power you may be able to hard wire a plug and mount a permanent lamp on a magnetic mount so you have the ability to remove it and also not have holes drilled in your roof
