No Brake Lights 99 Dodge Ram Van
Old 12-13-05, 01:57 PM
Floridacruiser
1999 Dodge Full Size Van: Turn Lights, Brake Lights and Hazards all quit working at same time. Replaced the Multi-Function Switch (on the column), Fuse Panel (drivers side end of dash). Still no lights!!! The fuse in dash panel and fuse under hood are OK. A local garage diagnosed the multi-function switch and the fuse panel after the new multi-function switch didn't work. They now say...........Take it to a Dodge Dealer!!! Trying to locate a wiring diagram so my buddy and I can diagnose problem.
Any help or suggestons would be appreciated.
Old 12-13-05, 05:48 PM
A
i need year make model and engine size and i will see what i can do
Old 12-15-05, 08:40 AM
Floridacruiser
No Lights
1999 Dodge Full Size Ram 1500 Van with a 6-cylinder 3.9
All help appreciated!!!
Old 07-07-13, 10:29 PM
No brake lights
I changed all bulbs and the switch above brake pedal, but still no brake lights on my 99 ram van 1500. All fuses are good and all other lights/signals work fine.
Any ideas?
Old 07-10-13, 05:09 AM
R
Received 1 Vote on 1 Post
Sounds like a supply problem, its unlikely that three switches would go bad at the same time. Possably a fuse link? You need a test light with a probe on it.
Old 07-10-13, 05:28 AM
the_tow_guy's Avatar
Received 53 Votes on 43 Posts
Or maybe a problem with a common ground? Either way definitely test light/multimeter time as wrench says.
Old 07-10-13, 02:33 PM
chandler's Avatar
Received 5 Votes on 5 Posts
If it is on a Dodge, you probably have a brake light switch gone south. BTDT. easy change out....tool less.
Old 07-10-13, 03:06 PM
Think he tried that already, Larry.
Old 07-10-13, 04:39 PM
chandler's Avatar
Oops, yeah. Is the switch releasing properly? Mine were slow to release and sometimes didn't release at all, thus replacement and alignment. But if it isn't getting a charge, it would be a moot point.
Old 07-10-13, 06:09 PM
I was thinking a connector has come apart. Coincidentally, last month when I took a week's vacation I had the wrecker at the tranny shop for a little work. When I picked it up on my return I discovered...no brake lights, no tail lights, no backups. Took me about 30 minutes of poking around the grimy underside of the back-end to discover the big connector that had been inadvertently pulled apart.
Old 07-11-13, 06:43 PM
T
I don[t know if this will help, but there is a website where you can download wiring diagrams, and I checked, there is one for this van. it is BBB Industries - TSB's & Wiring Diagrams - End User License Agreement Hope this helps.
