F-150 trailer light problem / need help
I have a 1997 f-150 pick up. I cannot get power to the running light pin of my trailer connector. I have traced the wire for opens all the way back up to the enging compartment. There are no opens or shorts. I have checked all fuses and relays under the hood and under the dash. The turn signals and break light pin on the trailer connector work fine. I pulled apart the multi pin plug under the hood and back fed the running lights wire to the trailer connector and it works fine.
I'm stumped???
I'm stumped???
hi
check for broken wire in harness.
I had that problem before
just used a test light and plug along the wire from front to back and see if there current going in i found mine where it cross over the frame and broke inside the wire casing
good luck
good luck
