2005 Toyota Highlander 4 wheel drive
Old 01-23-06, 11:56 AM
Cool 2005 Toyota Highlander 4 wheel drive
I have a 2005 Toyota Highlander and wanted to make sure I'm doing all that I need to use four wheel drive feature. All I have to do is press the ETC SNOW button on the dash and I'm in four wheel drive?
Old 01-23-06, 06:36 PM
LouBazooka's Avatar
read your user manual, most 4wd late models have an auto feature besides the standard command button to engage the 4x4 on which the computer senses the traction needed and automatically engages the 4x4 as needed.
remember when using the 4x4 :tight turns are a little harder,not recommended on dry asphalt,always keep the same size tires on all four wheels to prevent damage to the transfer case.
if you havent used the 4x4 before try to get the hang of it before you take on snowy roads.
