RV water heater: electric: tank, or tankless?
Received 0 Votes
I want to purchase an electric RV type tank, or tankless, water heater, not for an RV, but for my garage. I don't want a gas water heater, has to be electric. Thought that someone here might be able to give me some advice as to what kind and where I might find one. It's gonna heat water, mainly for washing my hands, in the garage. Is there one that you've had luck with in your RV? Thanks in advance!
Received 0 Votes
Unless space is the main concern you will likely find that the most cost effective route is to buy a small household water heater. The RV units will likely cost you more unless you buy used or salvage or something. You can buy a gas/electric RV type water heater and just not hook up the gas side. A search for RV salvage might get you some hits in your area.
Cost new will likely run a couple hundered dollars for an RV type water heater.. You should be able to find a 20 gallon electric household type for far less.
