1991 ford F150 Pushbutton Overdrive Problem
Old 06-27-06, 07:24 AM
P
My Uncle recently replaced his transmission on a F150 2WD pick up. It runs fine as long as he doesn't have the overdrive engaged. When it is engaged and the engine is warm the O/D tends to slip. I'm wondering if it's a computer or sensor problem?
Any Suggestions?
Old 06-29-06, 07:41 PM
billys68ss's Avatar
Is this transmission new or rebuilt? Or is it a used trans? It sounds like there is a pressure issue with the overdrive clutch, or worn components.
Good Luck,
Billy
Old 06-30-06, 08:12 AM
P
It was a used transmission. I'll take the truck out on the weekend and try to get a better description on what exactly it does and when. Hopefully it's a small adjustment as I don't want to put too much into it.....
Old 07-14-06, 09:51 AM
P
Driving test and second vehicle
Okay, I took it out and there is definitely an occasional slip when the overdrive is engaged. It usually happens when the passing gear is engaged but on occasion at highway speeds as well. Next question. I recently picked up a 1990 f150 xlt Lariot. Runs great but there is a "shudder" felt in the whole truck when you first start it and when you apply a lot of tork to tow something for example. No transmission slip in overdrive though. I'm wondering if it's as simple as the motor mounts? There is no problem starting and all sparks seem to be firing in sequence etc.....
