RV batteries
Old 06-28-06, 11:14 AM
RV batteries
my 99 Winn class A has 2 RV batteries I believe they are 600 CCA each, one will not hold a charge and is probably causing the other to go bad, well I figure I need to replace them both at same time to be safe, should I get one larger battery or stay with 2 of the smaller CCA size...any tips or accident avoidance to changing them myself
Old 06-28-06, 12:29 PM
Unless you have added a number of power draining accessories. stay with the same size, or check the manual or manufacturer for the original battery size.
Wear safety glasses; disconnect negative cables first, then positive. Reinstall positives first, then negative. Clean any corrosion on cables, in the battery tray, etc. with baking soda and water before installing the new batteries.
