replacing 96 gmc trk fuel pump
Old 07-20-06, 06:54 PM
Cool replacing 96 gmc trk fuel pump
What is best inormation source for replacement procedure...?
Old 07-20-06, 09:06 PM
find a manuel any where local library may have them to loan if you do not want to buy one
pump is in the tank
1)get as much fuel out you can
2) undo the filler neck
3) suport the tank between the straps
4) remove straps
5) lower tank a littel
6) remove lines and conecter
7) lower tank
8) open lock ring
9)remove sending unit replace whole unit or just the pump depending what you bought
10) to instal reverse removal instructions
