Catalytic converters
Old 07-22-06, 09:49 AM
I have a 1998 Ford F150 4WD 5.4 V8
Anyone ever hear of both catalytic converters becoming plugged at one time ??
What would cause this ??
I thought I also heard auto manufacturers had to warrenty cat for 10 years.
Any input will be appreciated
Old 07-22-06, 09:53 AM
nap's Avatar
nap
nap is offline
New Member
I have heard of both of them having a meltdown at the same time which would in turn cause the plugging.
If your engine is running rich it will cause the converters to glow red hot. Even the substrate in the converters can only take so much heat before melting. A rich condition can involve both engine banks which would cause both converters to be subjected to the situation.
Old 07-27-06, 08:50 PM
Thank you for that info.
Unfortunately this is exactly what happened to my truck.
Now the work begins trying to find the fuel problem that caused the cats to overheat.
Old 07-28-06, 03:50 AM
alot of manufacturers do have an extended warranty on emmisions equipment might check with your local dealer it is usually around 10 years or 100,000 miles.
