water pump runs ever 30 to 45 min.
Old 08-13-06, 05:57 AM
while dry camping I noticed my water pump would run on regular intervals. I looked for signs of leaks and found none. I also found that while connected to city water my fresh water holding tank would slowly fill and run out the over flow after 3 or 4 days. The problem was issolated down to the by-pass valve leaking. I found it easier to add another valve in the line than to replace the defective valve.
Old 08-13-06, 03:13 PM
A
the only time the pump should cycle is when demand is on the water so i would look real carefull for a leak do you have an out side shower if so this may be a good place to start
