power nailer (air)
Old 09-17-06, 08:00 AM
Georgekraus's Avatar
power nailer (air)
Which is the best brand for home use only. A air power nailer frame nailer 2" 3 1/2". Thank You
Old 09-21-06, 03:12 PM
For most tools, you get what you pay for. Since you are only using this for home projects, a less expensive framing nailer should work fine for you. I have a Central Pneumatic 10 Gague framing nailer that works great for me (except for the purple color). I've used it to build garage shelves and to frame and sheet a 10x14 shed. A friend of mine used the same framing nailer to finsih his entire basement without any problems.
Unless you plan on doing lots of framing work, an inexpensive framing nailer should work fine for you.
