1990 chevy k1500 speedometer drops to zero
Old 09-21-06, 04:57 AM
Angry 1990 chevy k1500 speedometer drops to zero
I have a 1990 chevy 1/2 ton 4x4 and the the speedometer will drop to zero while driiving down the road if I rap on the dash it will come back up it's not a constant thing and it seems after it gets warmed up? say 30min or so it will operate normallly,also it does'nt seem to make any difference on the road conditions. I have changed out the guage on the dash thinking it may have had a dead spot? in it,not w/ a new one but 1 from a salvage yard but the problem persists any ideas??
Old 09-21-06, 12:44 PM
If the problem STILL persists after you change out the cluster, then it could be your speed sensor. It can be the sensor is bad, or
a bad connection.
Alot of the times though, it's a gear in the cluster, or a worn needle.
Old 09-21-06, 02:15 PM
ok you mention gear are you refering to the odometer?
