1998 GMC PU Turns over but wont start HELP
Hello,
We have a 1998 GMC pickup full size extended cab 5.0 liters 4x4 and it wont start. It turns over but wont start. We have tryed putting gas line antifreeze in the tank and fresh gas and just recently had a oil change and tune up. Its got a new distrib cap and wires as well as plugs. When driving it a week ago it was raining and I started it up after driving to store and it acted like it was getting enough gas. We can hear the fuel pump start up when you turn the key, we have charged the battery, the lights and radio work when the key is turned. Please help.
Thanks
Wayne and Heidi
Thanks
Wayne and Heidi
Test your fuel pressure. Just because you hear the pump turn on, doesn't mean it's supplying enough fuel. Also, have you changed your fuel filter lately?
Could be a few other things:
Blocked/clogged cat (exhaust)
PCV valve
throttle position sensor
Check your vacuum hoses as well.
PCV valve
