Got the blues
Old 12-12-06, 03:06 PM
Got the blues
I have an 88 Ford E350, Desiel, it is running ok, well seems ok, but the exhaust is always blue and very smokey and very pungent smelling. What is the problem???
Thanks,
Jones
Old 12-12-06, 06:09 PM
HotxxxxxxxOKC's Avatar
It could be:
Clogged PCV valve
Piston ring set
Piston
Valve guides
Valve stem
Worn engine block
or rich fuel
I would check the PCV valve or the possible rich fuel. Those are your cheapest.
Old 12-12-06, 06:15 PM
blue smoke is mainly oil and unburnt fuel due to damaged motor.
Old 12-13-06, 08:02 PM
It does not seem to be using a lot of oil, how do I check or fix rich fuel??? Where is the PCV valve???
Old 12-14-06, 02:18 PM
Disregard the PCV valve. Diesels do not have them. To check if you have a motor issue, have someone do a compression check on the cylinders.
Old 12-14-06, 07:24 PM
michaeljp86's Avatar
When was the last time you changed the injectors? A poor fuel spray will cause a white somtimes blueish smoke. I would recomend changing them because if you dont have a good spray of fuel it can pit the top of the piston.
Old 12-22-06, 04:07 AM
I think michaeljp86 got it....bad injectors will cause bluish smoke and the pungent smell is indicative of bad injection. Blue smoke is normally caused by oil....diesel fuel IS oil.
