2001 chevy silverado power window problem
Old 12-23-06, 10:58 AM
T
Question 2001 chevy silverado power window problem
passenger window wont go down of vehicle listed above. when operating switch from drivers side I can hear a click that sounds like the switch on the passenger side, window dont move.
any ideas or ways to test switches or motor.??
Old 12-23-06, 11:03 AM
HotxxxxxxxOKC's Avatar
You will have to remove the passenger side door panel.
Once door panel is removed, you will see the harness going into the power window motor, you want to test for 12vDC at plug while window switch is down, if you get voltage, that means your motor is bad. If you get no voltage at plug with switch down/up, you have a bad switch.
Old 12-23-06, 10:25 PM
T
window issue
Mark,
thanks I will try it in a day or so.
apprecaite it
John
Old 01-03-07, 05:49 PM
window problems
John,
you can test the window switch by popping the trim the switch is held in up and get access to the switch and make sure to ground the test light to the truck not through the switch if you have power out of the switch it is a bad motor and then you can take the door panel off to do the motor later when you get one and the motors for those come as an entire regulator assembly not just a motor
