travel trailer tires
Old 03-10-07, 01:59 AM
What kind of problems would be encountered using auto tires instead of trailer tires on a 29' travel trailer?
Old 03-10-07, 05:45 AM
GregH's Avatar
Super Moderator
A tire that is designated for trailer use usually has a stiffer sidewall to prevent side sway.
Old 03-11-07, 04:35 PM
Arn
Arn is offline
I've heard of people using "LT" tires as they have a stiffer sidewall & will take more air pressure, but I think you're asking for trouble if you try "P" tires. You'll end up with too much flex & roll which could lead to a sway problem.
Old 03-11-07, 08:54 PM
OK, Thanks.
Old 03-12-07, 06:26 AM
Pendragon's Avatar
I believe that trailers tires also have a higher load rating for their size than an auto tire, probably due in part to the stiffer sidewalls mentioned.
Old 03-12-07, 10:33 PM
LouBazooka's Avatar
Don't learn the hard way
I have a couple of trailers and trust me you do want to use trailer tires not auto tires on them.
Yes they're more expensive but well worth it.
