2000 Georgie Boy Problem
Old 03-19-07, 09:31 AM
Question 2000 Georgie Boy Problem
I have a 2000 Georgie Boy the suite with a starting problem. It is on a Workhorse Chassis, It is a gas burner"Vortec" Will not start no dash lights, nothing. Replaced all batteries, coach batteries and engine battery. When using the assist to crank it, I do get dash lights but nothing works! Checked all fuses, none blown.
HELP
Old 03-19-07, 09:35 AM
check for a bad fuesable link by the starter also check wireing at ignition switch
Old 03-19-07, 09:38 AM
Will the line have a fuseable link that is marked???
Old 03-19-07, 09:51 AM
fuesable link is just a special type of wire that will come apart if a problem comes up just check wires cocected to starter make sure not broken if not tug with light presure to see if it brakes or feels broken it is no uncomen to be broken inside wire insulation
