'02 Chevy Silverado HD D-Max window problem!
Received 0 Votes
I rolled my window down the other night and it wouldnt roll up. It tries to move, but only a few inches and then feels like it binds up! I took the door panel off and tried to get to the problem but cant find it! Any ideas would be great!!
Received 0 Votes
check that there are no linkages off and catching in the windo also try and see if the gear on the mechinizim is binding you may be able to free it up also are the windows manule or power?
Received 0 Votes
if this is a power window there is no fix that can be done the cable is bound up or caught where it cannot be freed the only fix is to buy a new window regulator it comes as an assembly with motor and new cables and is easy to install and yes I did say new not used or junk yard you will run into the same problem if you dont buy new
