wheres egr valve on 86 yoda truck?
Old 04-06-07, 03:17 PM
D
just bought this truck and old owner says it needs new egr valve, very pricey not sure were it is. i am sure it guzzles the gas with a bad egr
its a 86 toyota truck with a 4 cyl. 22r engine.
please help
thanks
Old 04-06-07, 05:45 PM
the_tow_guy's Avatar
Received 153 Votes on 118 Posts
Check here:
http://www.autozone.com/az/cds/en_us/0900823d/80/18/91/36/0900823d80189136/repairInfoPages.htm
Be sure you remove and clean the valve and check for vacuum hose leaks before you condemn the valve. Very often EGR problems are associated items and not the egr valve itself.
Old 04-06-07, 05:47 PM
HotxxxxxxxOKC's Avatar
Should be on the top or sideof the motor. Here's a link to help you. They got some pictures of it towards the bottom of the page.
Old 04-06-07, 05:49 PM
Received 28 Votes on 27 Posts
Rear of engine right at the end of the intake manifold(passenger side). It's a pancake looking affair, about three inches in diameter, with a vacuum line running to it.
Hope this helps,
Bob
Dang Tow! You beat me by 2 mins. I must be slowing down....:-(
Old 04-15-07, 01:07 PM
D
thanks guys, i found it , replaced and runs a little better
what are the "associated" parts you were talking about cause it still runs a little rough, dont know about the gas milage yet, thanks chris
Old 04-15-07, 01:51 PM
Have you changed your PCV valve yet?
Old 04-15-07, 04:52 PM
Other things to look at on that particular engine are the timing chain guides and the tensioner.
Pull the valve cover and look down the timing chain at the front of the engine. You'll be able to see those things. If worn out or broken you'll have to think about replacing them.
Hope this helps,
Bob
