96 Sierra C1500 305 Vortech Vacuum Diagram
Old 04-12-07, 06:59 PM
U
Question 96 Sierra C1500 305 Vortech Vacuum Diagram
Does anyone have one or know where I can get one?
Thanks.
Old 04-13-07, 11:08 AM
A
you can go to your local library and borow a book book store and buy a book
look under the hood thereb should be one there
also i beleave you can go to www.alldata.com they will alow you to do one vehicle look up i beleave if none of that works let me know in a pm and i will see what i can do
Old 04-23-07, 06:05 PM
vac diagram
Why do you need a vac diagram there is only 4 vac lines on a 96 engine one goes to the brake booster one goes to the pcv valve and one goes to the EVAP canister (the round thing about the size of a coffee can on the drivers side of the engine compartment ) and one to the evap purge solenoid on the pass side of the engine next to the coil hope that helps you out
