larger tires on my 2004 silverado
Old 05-17-07, 10:41 AM
E
Unhappy larger tires on my 2004 silverado
I have stock 16" rims and tires. Want to know if i buy 17 or 18" rims and tires will this
affect my speedometer reading. Can't find a lot of hot rims in 16" for o4 chev.
Old 05-17-07, 10:46 AM
Received 1,183 Upvotes on 1,141 Posts
It's the diameter of the tire that matters, not the wheel.
Old 05-17-07, 10:52 AM
Received 724 Upvotes on 634 Posts
There are a few web sites that will help you caculate speed differences with tire size changes - only I don't where they are
What I've always done is read the odometer along with mile markers on the interstate - low tech way of getting you close. You can also buy speedometer adapters to speed up or slow down your speedo as needed.
Old 05-17-07, 12:10 PM
IT's the VSSB ( aka the DRAC, I think?)
It's a small box under or near the ECM. It's the one that adjusts the radio volume - it also affects the speedometer readings. It's possible to adjust the jumpers to allow for different tire sizes. A few have DIP switches, most have soldered jumpers.
Internet search on one of the above can yield some idea of what's involved.
Old 05-17-07, 03:22 PM
here is a site
Google this site miata.net good info there.
Old 05-18-07, 03:22 PM
HotxxxxxxxOKC's Avatar
Yes, it will alter your speed.
Look up that miate site like michael said.
You have also considered whether or not those tires will fit on your vehicle without rubbing?
Old 05-19-07, 09:47 AM
jatco's Avatar
Received 1 Upvote on 1 Post
http://www.miata.net/garage/tirecalcold.html
Its not just the tires to consider fitting properly, but the off-set of rims.
Too large or small of an off-set will cause rubbing of the rubber to the wheel well..and or not clearing your calipers.
What model Chevy?
