need help changing rv toilet
Old 05-20-07, 01:19 PM
Question need help changing rv toilet
I have a Fleetwood Terry 28 ft pull type rv trailer with a thetford aqua magic pedal flush toilet. I need detailed instructions on how to remove it and replace with a new one. It is leaking in the back and there is no visible way to get to it without removing it. Can you help me?
Old 05-20-07, 08:34 PM
can you work bakcwadrs? :)
I found installation insgtructions for 2 models.Maybe work back from them?
http://www.bluestreakchem.com/thet_aquamagic5.html
http://www.bluestreakchem.com/thet_aquamagic4.html
sorry I couldn't help more.
Old 05-21-07, 06:41 AM
Have a look at this link, it may help you. If you have that little front cover, snap/pull it forward. Sometimes they hang on pretty good so it could take some effort.
http://www.thetford.com/HOME/Products/PermanentToilets/AquaMagicVFootPedalFlushwandwoWaterSa/tabid/106/Default.aspx
Old 05-21-07, 06:48 AM
Additional to last. My guess is that if your in a cold climate & didn't get antifreeze through that water valve assy, during winterization, it's probably cracked & needs replacing. Check the PDF manual, and parts link, and between the 2 of them you should get through it. Usually the easiest way to change that water valve is to flip it upside down to get at it with a philips screwdriver. Seat and lid should pop off if you lift it a bit and push towards rear of toilet, it should unsnap, to make your job easier.
