coleman Arcadia ceiling replacement
Old 07-20-07, 06:14 PM
I purchased a early 1990's Coleman Arcadia Popup Camper. The ceiling around the Ac unit is bubbled and needs replacing. I suspect that water has weekened the particle board. There are no water stains in the ceiling. How difficult is it to replace that section of ceiling and can i do it myself?
Help
Brett
Old 07-24-07, 04:05 AM
I can't picture the arcadia at this time, but most colemans had basically the same set-up, so I'll see if I can help. I'm guessing you have the white bubble style aluminum on top, and white or off-white ceiling panel. Depending on how big the unit is, you may have strips of molding running across at 4 ft.
The hardest part is usually cutting it out and peeling it off, as they are usually laminated panels, or panel. I'm guessing your A/C unit is close to center of the trailer & probably center of a 4ft panel, with aluminum straps running across? Give me a little more info on what your looking at, and I'll see if I can help.
