dalel20
Old 08-04-07, 10:41 PM
Thumbs down dalel20
My nephew has a 1993 GMC Sierra with an auto trans behing a 6cyl. It seems to be intermittent but the tranny won't shift up all the time sometimes it works fine but other times it will hang in 2nd gear. Do these have a vaccuum modulator? Any ideas??
Old 08-04-07, 10:47 PM
Thumbs down dalel20
I have another question for you pros. 1998 Chevy 1/2 ton ext. cab 4x4. My fuel gage needle vibrates really, really fast. It is at all times until it gets to below 1/4 tank. We had a new pump put in under warranty about 6 years ago. When I bought the truck off lease they put a standard cluster in it. It was a Canada truck the read in KM. Any ideas???
Old 08-07-07, 08:47 AM
as for the first one do a fluid and filter change may have a sticky valve and now for the second did gm change the whole sending unit when changing the pump?? thay do have problems with gage sender as you discribed if you ask the the right gm parts guy there is just the sender avalible without the pump asy.
