2002 mallard floor repair
Old 09-10-07, 02:20 PM
soft floor in bedroom leak is supposed to be coming in from awning support bracket on trailer need to repair floor any suggestions
Old 09-13-07, 05:38 AM
First of all, I hope you fixed the source of the leak. Second, do you see any wall panel damage? If your going to do a fix, do it all at once & save yourself the hassle of going back later. If you can feel bumps on your wall panel in that area then it probably has been wet too. I assume that if it's the floor only, that it was your lower awning mounts that were leaking. If it is the lower, be prepared to replace the 1x3 in behind the siding too. Replacing the bad parts of the floor isn't too bad if your the least bit handy with tools. Give us some more details if you can, and I'm sure we can walk you through it.
