changing rear axle seal 2002 ford 150
Old 10-17-07, 05:34 PM
Can anyone give me a step by step on how to change rear passanger side axle seal
Old 10-22-07, 12:19 PM
remove tire and drum remove diferental housing cover remove center shaft (after removal do not turn diferental or wheel gears will fall out you do not want that to happen) go push axel in twords diferental remove c clip remove axel remove seal replace than reverse seal diff with automotive rtv
good luck
