86 K30 Fuel Pump Issue
Old 11-20-07, 11:02 AM
W
My Truck Has Duel Tanks . Fuel Pump Was A Mechanical Bolt On. THE New Block Requires Me To Use Electric . Im Not Sure The Procedure.
Old 11-21-07, 09:25 AM
A
if you are useing he same fuel system just go and pick up a universal low presure fuel pump that mounts on frame or fender find power that is constent in run and start tap in to this with a fuseable link and hoke up good ground easy fix
Old 11-27-07, 08:47 PM
H
86 k30 fuel pump.
Make sure that you have a cut off switch wired into the oil pressure sender. If you get into a wreck and the engine dies you don't want that pump to pump fuel out all over the underside of the rig when you might be inside. Its not hard to do and you maybe able to do it just make sure it has the cuttoff wired in there. Good Luck MIKE
