91 Ford 350 Fuel Gague
Old 12-02-07, 12:02 AM
my fuel gague stays on empty. is there a test i can do to determine weather is the gague or the sending unit.
thanks
Old 12-02-07, 05:01 AM
chandler's Avatar
Is it the front or rear tank? If the front tank, you can check your wires pretty straight forward by looking over the top of the drive shaft. I had this problem once, and apparently rats had chewed through my sending unit wire. Simple fix. Now, it could be not only the sending unit or gauge, but it could just as easily be the tank switch. Check the connections there.
Old 12-02-07, 05:44 AM
a single 40 gal tank. any ideas as to the colors of wires ??
Old 12-02-07, 11:00 AM
jatco's Avatar
Not sure about the color of the wires..and hopefully that is the problem.
On my '88 Ranger, when the gas gauge always read empty.. it turned out to be the sending unit/float in the tank. The original was made of brass..and over the years degraded to the point where it took on fuel and sank to the bottom of the tank. The replacement float is plastic so it shouldnt happen again.
Take a look thru this forum....
http://www.ford-trucks.com/forums/se...1&pp=15&page=1 ..
Im sure there would be some info there to help ya.
Old 12-27-07, 06:38 AM
dead on.....after spending close to $500.00 turns out to be a $3.00 brass float with a hair line crack. oh well at least it is fixed..
Old 12-27-07, 07:22 AM
the_tow_guy's Avatar
Dating myself a little here, but some carburetor floats used to have that problem and would cause flooding.
Old 12-28-07, 06:38 PM
jatco's Avatar
...Uh. - Yep, I hear ya...lol.
