95 ram 2500 turn signal problems......
hello, i am new to this site. i have a 95 dodge ram cummins 2500 that has some turn signal issues. it seems to be the only electrical problem the truck has. the hazard lights are working. i have already changed the turn signal switch and it has not solved the problem. i have also looked at the fuses. i just looked at the tail light bulbs, will be looking at the front lights next weekend. i have talked to a couple of people and they are stumped, as am i. has anybody had this problem, or any suggestions on what i should do next?? thanks in advance for any suggestions.
I agree. Look on the driver's side behind the #1 battery and remove the cover from the big box. Check the flasher module. The legend is under the cover. Are the lights flashing at all; are the flashing fast; do they light up or stay off? My 3500 signal lights operate whether the ignition is on or off, so it may be a power thing, too.
