Help with rv welding
Old 03-27-08, 07:43 PM
Hello, I need help....
I am a new welder and looking to do some repairs to the underside of my travel trailer.
I notice that there is a lot of wood and other combustibles on the bottom of the traielr but I need to do some frame repairs.
What precautions do I need to take in order to weld and repair my framing?
Thanks,
Jay
Old 03-27-08, 08:47 PM
That can be a little tricky. You have to lift the wood from the metal you're welding and shield it from the heat. This is no more than common sense. What can cause a problem that isn't so obvious, though are the fasteners that attach the wood to the frame. Some use a screw down system.
The problem is, when welding, the metal the screw heats up and transfers heat up through the wood and can start a fire that is difficult to extinguish. If you're welding in close proximity to something like that, I would take extra care to avoid heating the fasteners or clip the ones that could get hot.
I would lift the wood from the frame in the area of the repair, wet it some time before welding, and shield it with tin foil.
Hope this helps,
Bob
Old 03-28-08, 05:35 PM
And don't forget you have PROPANE LINES RUNNING UNDER THERE TOO !!!
