2001 Ford Ranger 4x4, 4.0 fuel injected
Old 05-07-08, 11:38 AM
I connot start a 2001 Ford Ranger 4x4, 4.0 fuel injected. I have tested and there is no power getting to the fuel pump. Have checked all fuses. Truck had been sitting for two years before I started to get it in shape to sell. Any suggestions will be appreciated.
mwalling57
Old 05-07-08, 08:47 PM
Speedwrench's Avatar
should have a relay to the pump. check for that, also check for pump shut off, there is a switch designed to shut power off to the pump in a accident see if you can reset that. the pump only has power for about 30 sec when starting unless you have either oil pressure, or it senses crank pulses, i forget which one ford uses. do you have a shop manuel?
