2000 Z71 a/c problem
Old 05-25-08, 09:17 AM
The problem- The a/c comes on, cools great for about 3-5 minutes, then blows warm air. It may start back, sometimes, after about 10 minutes. It will sit at idle for an unlimited amount of time blowing cool air, but when it is idled up it stops.
What I've done so far- Went to the dealer (the only people in my area that work on a/c) and they said it needed servicing ($145.00). Did the same thing. Then they said the low pressure switch was bad ($75.00). Did the same thing. Then they said the fan clutch was bad ($175.00). Still did the same thing. Now they say the compressor is bad (they want $1500.00 for that). They told me about an electro-magnetic switch in the compressor that is 'probably' bad.
When it is hooked up to gauges (I don't remember the exact readings) the low side remained steady and the high side dropped after reaching high idle. I don't have access to gauges but if needed I will plop down $$$ for them.
Any ideas? It has been suggested to try recharging with a can of R134. I can try that (I have a can of it and a hose) but I cannot tell which outlet is the low pressure side.
Any help is appreciated.
Old 05-26-08, 07:21 PM
would probably get a second opinion as obviously the dealer is at best guessing would find an independent shop that does a/c work to diagnose the problem make sure you go into detail about its symptoms so they can duplicate the problem.
Old 05-26-08, 09:51 PM
Speedwrench's Avatar
unfortunately I am not up on late model ac but sounds like that dealer needs to be taken off of your list of approved service providers. does your model have auto temp control?
Murphy was an optimist
