1993 f150 6cyl dul tank
Old 05-28-08, 11:36 AM
i would like to know how to change my gas filter on frame? i need to know how to de presure my sestum to change filter. and if i need a tool to take filter off, or just pull?
Old 05-28-08, 11:56 AM
to depresure the system if you look on the fuel rail on the intake you will see a shrader valve there remove capand release presure as if you are letting air out of a tire watch for spray also you will need a ford fuel line disconect tool unless it is the one with the plastic locks if you look at the end of the filter see if you can see a plastic lock holdding the line to the filter will look like a triangle slide driver under triangle section and pop up if it brakes shouldenbe a problem the new filter usuly comes with new ones maybe check first if it dose not have plastic lock than tool is requiored once you see tool you will know how it works
Old 05-28-08, 12:23 PM
f150 fuel filter
thank you so verry much. this info is what i needed. God bless you. blindwilly
