F-150 tranny problem
Old 07-21-08, 05:09 PM
I have a '93 F-150 truck. Its a 5 speed standard, 4 wheel drive, V6. None of the gears work at all, and even when the truck is running without using the clutch, there is no grinding or anything. The clutch has plenty of pressure, so I assume its either the tranny or mayby the linkage. Any ideas, and if so, how can I fix the problem? Thanks.
Old 07-21-08, 05:13 PM
Have you removed the shifter boot at the floor, and look down where shifter goes into tranny to see if maybe a shear-pin or something is gone? (just an idea)
Old 07-23-08, 06:15 PM
Yes, I did remove the shifter boot, but I didnt see anything unusual. I didnt see any shear-pin, only screws.
Old 07-26-08, 09:31 AM
transfer case is engaged good?
Old 07-28-08, 07:26 PM
I think so, it seems to be fine
Old 07-29-08, 03:39 AM
Painter,
any noise coming from the clutch/bell housing area? Does the trans feel normal when it goes into gear? Sounds like the trans will have to come out to fix any way, so why not pull it out and have a look at clutch and input shaft?
Old 07-31-08, 04:47 PM
Yeah, by the sounds of things the tranny is definately gonna have to come out....yay
Old 10-09-08, 04:09 PM
Slave cylinder removal
Hey guys, I got the tranny from my F-150 down on the floor. I took the clutch and pressure plate off, and I was just wondering if somebody could tell me how to remove and bleed the slave cylinder.
Old 10-10-08, 03:43 AM
Here's a link for the removal and installation of the concentric slave. I'm sure that's what it has.
http://www.autozone.com/shopping/rep...00c152801cd94b
Old 11-03-08, 02:54 PM
is the transfer case stuck in neutral?
