service 4 wd light on in message center
Old 08-07-08, 04:54 PM
2000 Chev Silverado 4- WD changed the transmission fluid,
front and rear differentials.
How do I get the light to turn off in the message center?
Old 08-08-08, 07:13 AM
Scan tool requiored
Illumination of the Lamp indicates a problem with the drive system.
There will probably be a Transfer Case Code set to aid in diagnostics.
The only way to get the light to go off is to clear Transfer Case codes.
This light can NOT be shut off or reset any other way.
Transfer Case codes should be read and repaired before clearing them
